I've recently fitted a Manitou Minute MRD w/ Absolute damping to my Nicolai Helius CC. The fork is the 130mm model
First couple of rides: good. The fork disappears and is stiff as a stiff thing. I like this fork!!:thumbsup:
Could be a little more plush I think, so I'm giggling the pressure: put fork upside down as per instructions and as I deflate the fork (slowly as per manual) I notice the fork is sucking down. Basically the fork is losing travel, so that when I set it to where I think I need it (c. 60 psi) I have only 95mm of potential travel.
I notice also that if I re-inflate to, say 150psi the fork extends to allow a potential 128mm of travel. But if I deflate (real slow, as in reeeaallly slow) eventual the fork sucks down again. :madman:
I leave the fork at 100psi and about 100mm of maximum travel. Then I notice the Absolute damping is no longer working at all. Throw the lever all the way to the right: no change. :madmax:
So I'm stuck with a < 100mm fork with no means of controlling low speed compression damping. And I'm not wholly sure the fork is still safe to ride.
A few people have stripped this fork down: is there something serious amiss, or is there an easy remedy? I live in New Zealand and bought from ChainReaction Cycles in UK and have had a world of pain dealing with them. Manitou are not common here in NZ so I am hoping I can service the fork myself. I'd like some advice before diving in!
Any ideas? I like this fork but it seems to be very sensitive to fettling.
