1 - 3 of 3 Posts
anyone know if therre is a way to disable the infinate travel feature on a manitou minute 4? i would like to just keep it at the full 130mm travel setting..... when the weather is cold the fork keeps drifting down (especially on downhills where the fork is compressed alot)... i know its not a problem with the valve/cable as ive had it apart and cleaned it etc... .. seems to be the seals inside the fork...i don't use the feature anyway so was thinking about disabling it...
check with where you bought it, losing travel occasionally happens with IT forks, and is usually repaired under warranty.
A possible workaround would be to add some oil to the air chamber (in case it drained out of the air valve and the seals are dry now).
1 - 3 of 3 Posts
