OK, deleted my long and detailed original message:madman: so this is gonna be a little curt..
Hey Andrew,
You #1 answer sounds likely to me. I think Ronnie is on the right track with the custom OEM fork idea. It does appear to be a new bike pulloff. It looks new, but installed, with all original stickers, including the "TPC lockout" sticker. At first I thought it might be a guys custom job, but the original TPC sticker leads me to believe it is a factory custom. Wonder why a manufacturer would spec a custom for like that?
I did remove the red lever, then unscrew the large black cap. It comes out to the end of the threads, but then doesn't want to go any further. I'll try a little harder next time.
Ronnie,
It has what appears to be an original "TPC lockout" sticker on the side, so I assume
that it has TPC. What other types of dampers come in these things? Is the TPC damper a good one?
Also, I did email Manitou tech support about dialing-in the "platform -plus." This is the responce...
"Brian,
The damping is based on platform technologies through the shape of the
piston, the way the shim are controlled and the way the adjusting needle
works in the piston. It works by turning the red knob at the top of the
crown. We did not develop a lock out system for this fork."
So, appearantly they would consider it an oddball too!
So do you guys know what the different type of guts are, that go in these things?
Is it only TPC or SPV?
Can one have SPV with lockout?
I'm wondering if I should try to find a SPV damper to try out... you guys like em?
The lock sure is handy though, especially if I can fit a handlebar control.
Looks like I'm gonna' need (get)
to take it apart.
Thanks again, Brian.
Oh yea, I have both Shock Nectar and Specro fork oil. I don't think either one is synthetic. Is non-synthetic alright? B.
OK, I couldn't take it anymore! I pulled it apart, very easy indeed. Seems the reason the top damper wouldn't come out is bacause the bushing was still real snug. I "pumped" it out using the bottom damper.
Here is the photo. TPC? Also, is non-synthetic OK? and what goes in the oil bath?
B.
