The Manitou Mezzer is here! lets get into some details!
37mm Chassis that is the stiffest single crown fork on the market.
Torsionally, the Mezzer is 30% stiffer than a Fox 36, 16% stiffer than a Ohlins RFX36, 1% stiffer than a Lyrik
Fore-aft, the Mezzer is 7% stiffer than a 36, 20% stiffer than a RFX, and 4% stiffer than a Lyrik
140mm-180mm travel in both 27.5" and 29" wheel sizes. Boost 110 only. 37mm and 44mm offsets available for the 27.5 forks, 44mm and 51mm for 29"
2000g for a 180mm 27.5' fork
Dorado air spring with larger negative air chamber for linear initial stroke, IRT chamber volume has been reduced to add progression for the big hits.
Bladder style MC2 damper to reduce friction. 5 clicks HSC, 10 clicks LSC, 12 clicks LSR.
HBO circuit provides extra bottom out resistance for the last 30mm of the stroke. No external adjustment ( The IRT volume adjustment provides enough progressiveness that its not needed)
Bladder cartridge has a blow of valve (BOV) to prevent it from over filling between services. No ruptured bladders here.
