Stock Mezzer vs tune Lyrik?Mezzer. No contest.
Full disclosure: I'm a Manitou distributor and Hayes test rider. I also upgrade and tune Lyriks.
Impartial reasons:
Mezzer has a far better damper with better sensitivity, support and adjustment range.
Mezzer has HBO (hydraulic bottom out).
Mezzer has a far better air spring with three chambers (positive, negative and second positive chamber (IRT) for seperate mid to end stroke tuning).
Mezzer is travel adjust by clip in spacers, no need to buy air-shafts.
It just works better.
It takes a lot of money to make a Lyrik perform like the Mezzer. You're talking Vorsprung smashpot and damper modifications/tuning. We have customers that do that.
The Mezzer has nuts on the bottom so the only special tools needed for work is a slotted cassette tool.Tuned in. Invading this thread as I'm looking to get a new fork and the Lyric and Mezzer are my top two.
The Mezzer sounds better by what the suspension guru's are saying on these boards - at least regarding the damper and air spring. But for as bad as some folks say the Lyric's damping is I've seen a lot of pretty fast dudes using that fork.
I do like not having to buy a separate rod to change travel. On the other hand I can likely get a rod for less than the Mezzer tool kit it appears one would need to work on that fork.
The Mezzer, IMO has not been out long enough to tease out all the potential QC issues. The Lyric has been beat and dialed for a long time so might be considered potentially more reliable.
Resale on a Lyric might be better as folks are more likely to buy something that is more common, or that they already have experience with.
Personally I can tear down RS forks for simple service super fast. Not sure how hard that sort of thing is with the Mez.
Probably just live with what I have and see how things shake out with the Mez then maybe get one in the Spring.
Good luck.
That's easy.Stock Mezzer vs tune Lyrik?
Nice. Thanks.The Mezzer has nuts on the bottom so the only special tools needed for work is a slotted cassette tool.
The reduced diameter 8mm socket and 24mm flat face socket for the Mattoc isn't needed for this one.
The lower nuts also make service very quick and easy. No crush washers and no hammer tapping. For travel change the lower legs hold all the bath oil. Take them off horizontal and it's only drips on the shaft to deal with.
The only new parts on the Mezzer that could be perceived as a risk is the bladder on the cartridge damper. This is a new design feature for Manitou. Everything else is existing tech upsized a few mm.
Mezzer crown is 3mm thicker than a F36 (just measured both, 25 vs 28mm). The rest of the A-C difference will be tyre clearance.There is another consideration - Axle to Crown. If you're particular about getting the shortest fork with the most amount of travel, the Mezzer is a 7mm longer than the 36.
It also gets slightly heavier as you shorten it. It's the lightest 180mm 29er fork available, but on the flip side its slightly heavier than the 36 or Lyrik at 140mm.
In pretty much every other way its superior to the Lyrik and 36. It has the best stock air spring of any fork aside from a dual chamber cartridge or Luftkappe (which are add-ons).
I've kinda chosen the Mezzer as my next fork, and the only way I'd not buy it (sometime next year) is if Rockshox or Fox significantly lighten their long travel forks while adding stiffness, or if someone releases a travel adjustable coil fork (with spring weight for a 250lbs rider and a good damper) that is under 2100g. We'll see how long Manitou can retain this lead.
Seems hypocritical. Is it possible to fat-shame a fork?a 250lbs rider... that is under 2100g.
Wait, is a 250 lb rider complaining about a 4.2 lb fork?Seems hypocritical. Is it possible to fat-shame a fork?
I'm a data analyst by trade. It's worth noting the small differences between products, especially when your paying $1000 for it. Some consumers will say "I don't care about the little details as long as it rides good." Otherwise will say "I need it to weight exactly 2000g or I'm returning it."Seems hypocritical. Is it possible to fat-shame a fork?
I don't have either...option A) Avvy tuned Lyrik or Marz Z1 or B) buy a MezzerThat's easy.
If you already own a Lyrik that is colour matched to your bike, get the damper modified and tuned.
Otherwise buy the Mezzer.
So wait... you are talking Apples to Oranges to Mangos here?I don't have either...option A) Avvy tuned Lyrik or Marz Z1 or B) buy a Mezzer
I have a Bomber Z1, it rides very well, Grip damper works well, it's a slightly stiffer and heavier chasis than a 36, also more reasonablely priced. I dropped a Smashpot in mine and it went from an eight to an eleven. Downside = heavy.I don't have either...option A) Avvy tuned Lyrik or Marz Z1 or B) buy a Mezzer
The premise of what I'm tossing around in my head is basically between tuning a common fork, in my case a used Lyric or new Z1's, or step up to a new higher tech platform. Tuning is $400, used Lyrik or new Z1 are $700, so call it $1100 all in. New Mezzer is $1k, so within spitting distance.So wait... you are talking Apples to Oranges to Mangos here?
Avy Tuned Lyrik - specifically created for you, your weight, your terrain, your riding style, etc. Average cost would range in the $1500 area unless purchasing a used Lyrik, then closer to $1k+
Manitou Mezzer - new fork on the market, little feedback but has proceeding reputation of its littler brother the Mattoc. Most will agree that it has the potential to be a great fork, just not enough varying data yet. Average cost is $1k.
Marzocchi Z1 - Basically a Vanilla Fox fork but with some updates. Has old Marz name and Fox backing (depending on your thoughts of Fox could be good or bad). Average cost is like $600 I believe.
So you got lots going on here.
What does it weigh out of curiosity.....your upgraded Z1.I have a Bomber Z1, it rides very well, Grip damper works well, it's a slightly stiffer and heavier chasis than a 36, also more reasonablely priced. I dropped a Smashpot in mine and it went from an eight to an eleven. Downside = heavy.
I ain't rode a Mezzer, but I trust Dougal in his assessments.
If I was getting an air fork and I had the dough, I'd try a Mezzer.
On a budget and don't want the weight of a coil, the Bomber Z1 or equivalent Fox works well.
But if you want a coil feel and don't care about weight, I'd get a Z1 Grip or a 36 Grip2 and add a Smashpot.
Edit: I didn't know the Mezzer had a hydraulic bottom out, this is a sweet deal, I have one in my Smashpot and it works great, can't even tell it's there, but it is.
