IPA stack isI miss read your initial post. Changes to the velocity stack will have no affect on lock out stiffness
You can add ( or subtract) 20mm shims to the IPA (10mm ID) stack to change the IPA adjust range and get a stiffer or softer lock out. You want to make sure to run at least 2 of the 10x14x.1 shims to allow enough room for the shim stack to have proper lift.
Most of the time, changes to the IPA stack require a eyelet adjustment to keep the stack and zero preload in IPA 1.
Do you know what your current IPA stack is?
10 x 14 x 0.1
10 x 14 x 0.1
10 x 20 x 0.2
10 x 20 x 0.2
10 x 20 x 0.2
I left the 10mm stack as is as I noticed you needed the 14mm to hold the 20mm off.
I set the compression stack as
8 x 10 x 0.1
8 x 16 x 0.1
8 x 14 x 0.1
Bouncing around the garage it seems better. We are currently under “shelter in place” but can ride locally as long as you bike to the trailhead. Luckily I live 3 miles from a large trail network. However it has been raining here like crazy. The rain is really helping social distancing as people in So. California hate the rain. Yesterday I replaced the brakes on my bike and tuned the shock.
Stay safe and thanks for the help
