ABS+ stock is better than any of Rockshox stock fork dampers. Including all the Chargers.
Oils are 15cSt damper oil (I use Motorex 2.5wt, stock is Maxima 5wt) and there are different levels for Kwik Toggle and ABS+. Check with Kwik Toggle that you can fully compress the damper shaft. I run about 3cc less damper oil than stock.
16cc of heavy lube oil in each lower leg. I use Motorex Supergliss, stock is Manitou Semibath 5W40 which is Motorex Powersynt 4T 5W40.
