Many of you were hanging out for a 37mm fork with the J-Unit launch on 11th April 2019 (US Sea-Otter). Sorry guys, this one is for your kids. With a little more patience you will be rewarded. So hang in there.
Hayes have just released the Junit (pronounced "Jay-Unit") line of Youth Performance products. 20" and 24" forks, wheels, brakes and bars so the young ones don't have to struggle under cut-down adult parts any longer.
http://instagr.am/p/BwIbQPCll2R/ https://www.shockcraft.co.nz/manitou-hayes/junit-range
The two forks (20" and 24") are built on the Manitou Machete Boost platform.
The air spring is Expert Air which is a simpler version of the Dorado air system used in the Mattoc forks. So positive/negative self balance every time you connect the pump and it can be easily spaced up and down for travel and height adjustment.
The damper is ABS+, fully tunable and revalvable.
They take the bolt-on mudguards (fenders) as the Mattoc Boost, with no mudguards they take a 2.6" tyre, with the mudguard it's a 2.3". Last years rear-facing mud-guard can be run with no tyre size reduction.
20": https://manitoumtb.com/product/machete-junit/?cat_id=23
24": https://manitoumtb.com/product/machete-junit/?cat_id=23
