I'm looking at a 120mm Machete Comp Boost 29" for my Top Fuel.
Does anyone know the actual weight? I'm seeing 2080g down to 1750g.
The Trek's stock fork is 100mm, and has a 51mm offset. The Manitou has 48mm I believe.
I need to check the axle to crown.
Anyway, would decreased offset and 20mm increased travel result in odd handling?
My current fork, Fox Rhythm 32 is harsh (it is killing my hands) despite tearing it down myself, and later sending it to Fox last year (they also found no issue).
My 18 year old, 80mm Manitou Six Deluxe is far more plush and active than the Fox.
No, I'm not kidding.
Unless someone has the cure (not speculation) for the Fox, I have zero interest in screwing around with it. It has been apart multiple times, has no spacers (I've tried some just out of curiosity), and even Fox didn't fix it, so harsh compression must be the nature of my fork.
Is the Machete a plush, active fork? I would probably upgrade to ABS+ at some point.
Many thanks,
Bob
Many thanks,
Bob
