I have been using an Axel Comp 03 for about a month and it sounds like it doesnt have enough oil in it(you know the squishy-air sound.) I bought it brand new from JensonUSA. I wanted to convert it from 80mm to 100mm so I decided to take it apart and try to see what was goin on at the same time. When I pulled the bottom bend off it had a quite a bit of oil in the right leg. I am worried that the seal is broken or defective. Does oil tend to leak out of the top end where all the oil is suppposed to be?
Also I couldnt figure out how to change from 80 to 100mm because the instructions were horrible. If anyone can help with one or both of these problems it would save me a call to Manitou tomorrow.
