1 - 3 of 3 Posts
I have recently got 2005 Manitou slider mounted on my Dirtbag replacing my Z-150.
I run a per of sram-9 (6 intch rotor) up front (same brake like old XT or Formula).
What kind of adapter do I need in order to fix the sram on the slider? and where can I get it? :confused:
Thanks :D
Meh.
Thanks :D
The SRAM brake uses a IS mount without an adapter right? You'll need to purchase an adapter from A2Z or EBC. It allows you to run IS brakes on postmounts. However, the offset is different, so you will need a larger rotor. You will need a minimum of a 10mm larger rotor.
1 - 3 of 3 Posts
