Anyone here got any experience with this fork? Wanna know if it's good for the flowy stuff and also most importantly, How tough are they???
yeah, but what about durability???XSL_WiLL said:I think he means that the stanchion tubes are turning or twisting inside the crowns. That even happens with the Shivers. The flex is there, since it is an inverted fork, but it's really not that bad. It tracks well, and that little bit of give is real nice in the rocky stuff.
Yeah, thats what I meant. It tripped me out, because I thought it was the usual stem slipped a bit, but the stem was dead center...and the wheel is about 5 degrees off. So anyway, I would recommend it if you are a careful rider and want a very light, plush great looking fork! I would not get one personally, I crash a bit too much.XSL_WiLL said:I think he means that the stanchion tubes are turning or twisting inside the crowns.
It's just something that tends to happen with most inverted forks. For the racer, the tradeoff might be worth it. Inverted forks are so much smoother and track the ground better. Less unsprung mass. Leaks can potentially be more of a problem. Since everything is inverted, the seals are constantly immersed in oil.Phi.Design said:Yeah, thats what I meant. It tripped me out, because I thought it was the usual stem slipped a bit, but the stem was dead center...and the wheel is about 5 degrees off. So anyway, I would recommend it if you are a careful rider and want a very light, plush great looking fork! I would not get one personally, I crash a bit too much.
They have their pros and cons, the largest of which XSL_WiLL & others mentioned.Rover Nick said:If inverted forks are so good, then why are they practically extinct by the big fork companies?
