Hi All,
I was originally discussing the damper in the best damper thread.
However getting more detailed, so worth running at a seperate thread. Might be useful to others too.
Where we are at:
I'm riding an xl evolink 158, this puts tons of weight on the front of the bike.
I'm running 90psi main, 122 irt spring.
The terrain I ride is rocky/rooty, varying from steep to flat.
Front tyre is Dhr2 29x3.
I've spent a lot of time on the Shockcraft website. Fully recommend it for everyone. Great tuning tips!
The only mods I've made to the fork is remove the floating tpc+ stack (I'm not use enough travel as it is, don't need even more hsc). I'm also following Douglas's tip on using motorex 2.5wt. That stuff made a phenomenal difference!
So currently rebound full open, hsc full open.
Lsc is a discussion point, but 4-6 from open (counting from 1 as first click).
The challenge is to get the front of the bike high enough to be able to drop off fine (had real issues nose diving this bike), whilst still being plush enough to flow over roots/rocks.
I'm currently doing this weird ways E.g. Secondary chamber low pressure vs main. If I use the +50% rule then it is far to firm and uses too little travel. If I lower the main pressure then the front end is too hard to loft for drop offs.
I'm still playing with pressures, however spotted something potentially key for lsc.
I sessioned a rocky steppy section to get the lsc spot on. Got rocky steps 6 is really smooth. A couple of clicks more and it gets too stiff. A few clicks less and it's too deep in travel, firm and slow.
However if I run 6 for general riding then I'm losing speed over choppy non-steep terrain.
I want the fork to flow over stuff when not steep, but still provide support on the steeps. I've got a video of me on the steps to show how fork responds.
Is this a base stack too firm thing?
Help!
P. S. Sorry about typos, writing in car. I will clear it up later
Where we are at:
Help!
