Or you can use 5w-20 or 30 if that's all you can find locally, because it really doesn't matter for the semibath.steve3 said:
Or you can use 5w-20 or 30 if that's all you can find locally, because it really doesn't matter for the semibath.steve3 said:Or you can go over to the right or left of that and use Rotella Synthetic for $3 and some change. That's 5w-40, or you can go to any European parts supplier because 5w-40 is a common grade for European cars.
I need some today!Homebrew said:Mobil 1 now has 5W-40 that is needed for Manitou's semi-bath forks. Less than $5 at my local WalMart.
It's different.opticals said:what the different in number the back after the 5W.
I'm think of getting the oil for my Marzocchi fork and everyone say go for 7.5W.
Since I can't get 7.5W, I'll go for 5W these time.
But what's the difference between the 20, 30 and 40?
I'm not entirely sure about this, but doesn't the Marzocchi use the same fluid for damping & lubrication? If so, the answer is no.opticals said:Can I use the mobile 1 motor oil for my marzocchi open bath fork?
Don't use Mobil 1 in your Marzocchi. Like Nate said, go to your local motorcycle shop and get some 125/150 (7wt) synthetic fork fluid. If they don't have that, get 5wt and 10wt of the same brand and mix equal parts to make 7wt. Just make sure when mixing oils to use the same brand. Look for brands like Golden Spectro, Silolene, Maxima, BelRay, etc.opticals said:Can I use the mobile 1 motor oil for my marzocchi open bath fork?
Going off of what Homebrew said, except we don't reccomend use of ATF in the forks... It usually starts to gum up the internals. Plus, a lot of ATFs have seal swelling additives. Stick with a good quality motocycle fork oil and you will be set.Homebrew said:Don't use Mobil 1 in your Marzocchi. Like Nate said, go to your local motorcycle shop and get some 125/150 (7wt) synthetic fork fluid. If they don't have that, get 5wt and 10wt of the same brand and mix equal parts to make 7wt. Just make sure when mixing oils to use the same brand. Look for brands like Golden Spectro, Silolene, Maxima, BelRay, etc.
And if you absolutely positively can't find any of the above, some people use Automatic Transmission Fluid (ATF) in their forks. It's a bit thicker than the regular Marzocchi oil but would probably work okay especially if you are a heavier rider.
