3 way on tracer...
Changing the rebound speeds on my 3-way makes a noticeable difference (I prefer it slow!)wiiija said:
Changing the rebound speeds on my 3-way makes a noticeable difference (I prefer it slow!)wiiija said:Could 3way owners tell me whether the shock has a night and day difference between fastest rebound and slowest? cos in all honesty I can hardly notice a difference no matter how much rebound I have (it always seems really fast),both while riding or just applying pressure,wondering if I might be wise to send it to tf for a full service and test.
wiiija said:Thanks guys.
The rebound damping seems shot on this,so it deffinately needs a service.I'm getting more and more tempted to go for the push spider monoblock and pushed rp3 combination,just dont want to pay out all that money and be dissapointed.decisions,decisions
Cheers
Sean
Send your Swinger to TF Tuned Shox as you are in the UK. A friend of mine had his 4-Way swinger done by them recently and he had good things to say. You can also get the Push Mono-Block for the Manitou shock. You should be able to get it from TFT. Be careful though. There is a difference between the Mono-Blocks for the Fox and the Manitou. I'm running a Mono-Block with a 4-Way Swinger on my 5point5 and I felt a big difference when it was fitted.wiiija said:Hi all,
I've just recently got myself an 05 spider for a very nice price (well nice for the uk anyway).I moved over from a heckler with a 5th air,I am shocked how much better performing the vpp suspension is on this bike,it really has blew me away.
Anyway,onto the subject,it came supplied with the 3way shock,this feels incredibly nice apart from one small problem i'm noticing which is the rebound.
Was originally planning to go for the monoblock and vpp specific pused rp3 but if I can get this sorted I can save myself a fortune.
many thanks
Ron, which one do you have, the AIR PORT Micro or the AIR PORT 90?Ronnie said:Its possible that you loose pressure when removing the pump but with most good pumps you should not. Here is a real little gem from Reset Racing in Germany which I use on my pump. (Click on Air Port or Air Port 90.) It allows the valve on the shock to close completely before removing the pump and there is never any doubt that your pressure is constant. Your gauge may not be accurate but the pressure is the same every time. You can order it direct and they'll ship it to you.
Ronnie.
Hey Ron, thanks. You have all the great toys. Looks like I'll order one of those babies this week. I had enough of the sssssssssssssssss when I take off my air pump.Ronnie said:Hi Jeff,
I've actually got both but I use the Air-Port 90. Its new and it goes onto the valve easier.
Ronnie.
Well I don't know about that! After all, its you that's got the 6point6.Cowboy-jeff said:Hey Ron, thanks. You have all the great toys. Looks like I'll order one of those babies this week. I had enough of the sssssssssssssssss when I take off my air pump.![]()
Hi Ronnie, I find when i use my Fox pump on my rp23 which was tuned up by TFT that on removing it i also get the escape of air? I assume then that is not coming from the shock but the pump itself? CheersRonnie said:Well I don't know about that! After all, its you that's got the 6point6.. By the way it still goes "sssssssssssssssssss" when you take of the pump but it is definitely pressure in the pump as you should have retracted the knob that opens the valve.
Ronnie.
6.5" x 1.5"babar said:who has the exact lengh of spider rear shox? Is-it a 160mm eye to eye?
Well I have something wrong with my Manitou swinger 3 ways, I am not able to measure the 160mm eye to eye shox lengh and not able to get more than 28 to 32mm of travel while normally it's supposed to be 38mm?6.5" x 1.5"
