Yeah any INTENSE pre VPP would do. I'm just curious what early INTENSE bikes are still out on the trail..starship303 said:by vintage you mean pre-VPP?
Great idea on the decals. You have a close up of the serial number is there something different about it?I'm sure its the same the person I bought it from I think raced for Intense-Maxxis. The decales are the most current I cut out the yellow.
"PROTO" too cool!"PROTO" is the serial number. Are you running gothic rotors? I have one in the rear wheel loking for a 8" for the front
You said you bought an old Tracer not an UZZ-SL correct? If so the rear travel is 3.5 " which makes a 130mm fork too tall up front. That frame is designed for a 80mm to a 100mm max. You could put a UZZI-SL link on and run a 125mm-130mm fork and have an awesome light all around trail bike.eluv, thanks for info. I actually have a Tora w 130 travel that I was thinking about putting on there but wasn't sure til now. BTW, like the rims on your MCS in the background.
