It is not to be worried about. That is the joint like you said, and the "crack" is only the clearcoat.jdubb12 said:
Ride and Smile!
Tim @ Salsa Cycles
It is not to be worried about. That is the joint like you said, and the "crack" is only the clearcoat.jdubb12 said:Went out for the first ride today and noticed there was a tiny crack where the carbon fiber meets the scadnium I remember someone else had this happen as well, does this happen on all of them? should i be worried? It seems to only be the paint that cracked.
Yup....seen it on more than one Mama myself. It's not a big deal.chequamagon said:It is not to be worried about. That is the joint like you said, and the "crack" is only the clearcoat.
Ride and Smile!
Tim @ Salsa Cycles
