I recently converted my cobia to singlespeed. I have been riding a lot lately, mostly in the city b/c of a healing wrist injury. I took my bike out for its first real trail ride the other day.
I survived surprisingly. I was kind of nervous as I had been off my bike for several weeks. I climbed well. The gearing I have set up now is 34 - 18.
While I feel this gear is good for riding the trails, I think I would like it to pedal a little bit easier.
The problem is that when I commute or just go out for evening rides in the city, I'm spinning like crazy and can't really comfortably go any faster than 14mph.
I'm really happy with my bike running one gear, but would like to be able to have an easy gear for trail riding and a harder gear for city riding/commuting.
I have an idea. Not sure if anyone else has tried this with good results..
I will run two front chainrings. One on the middle ring spot and one on the outer ring spot. Middle ring will be 34t. Outer ring be 36t. On the rear i will have two cogs with a spacer in between, each in line with the front two rings. Trail gear will be 34 - 19, commuting gear will be 36 - 17.
I have a surly singleater (sp?) so it will be easy to switch the tensioner between chainlines. With the two gear selections above, i will be able to use the same chainlength, so I can just manually side the chain over. Right???
Any experience with something like this? Think it could work?
