1 - 4 of 4 Posts
I think we should go back
What do you guys usually do to your casset,chain,deraillers,chain rings after a run that gets your bike muddy or snowy or wet? i HATE rusty chains and cassets and dont want to ruin the ones on my new bike.
If you have decent chain lube, there shouldn't be water in the chain, so you just need to use a paper towel to wipe the worst of it off the outside, if you want to) and let the rest drip or evaporate in a warm place.
If you chain isn't protected by a decent lube, you'll want to dry it as best you can using a hair dryer or the like, to prevent rust on the inside. You can also spray on moisture displacers such as WD-40, or LPS-1.
Drivetrain maintainance for wet riding is best done as a preventative, using good chain lubes that keep water out. This works better with less effort than trying to deal with it afterwards.
On my road bike, I never do anything after coming back from wet snowy rides, including exposure to road salt, and never have any problems.
Vaginatarian
pretty much as mentioned above.
If muddy I like to clean it asap preferably while still wet as it will mostly rinse off. then towel dry and re lube anything that needs it . I've had good results with the pink bike cleaners (finish line and muck off) they are supposed to have something that leaves behind a coating that eliminates spot surface rust (like inside bolt heads) I was told its silicone but I cant confirm, I will confirm that it works well
My routine is , hose the bike, spray the pink, scrub with soft brush, rinse and dry. Takes maybe 5 mins. tops
1 - 4 of 4 Posts
