Maintenance Questions
I've had my Mojo SL for a couple of months now. I rode a fifty mile cross-country endurance event in Wales two weeks ago (The Marin Rough Ride) and spent a couple of days in Dalby Forest last weekend (really good trail centre riding in Yorkshire). These two events have been responsible for a bit of wear, and I think it is time to thoroughly check the mechanical condition of various parts.
I've given the bike a good clean, inspected a few areas, and have a few questions...
My Chris King ISO hubs developed some lateral play and looseness in the bearings. The rear was quite noticeable, making audible metallic noises when shaken side-to-side. It needed significant adjustment. I reckon it's quite difficult to get at the pinch bolt without removing the rotor, and the bolt itself is steel and susceptible to rust. Anybody else think the design could be improved? I would be interested if anybody knows where I might be able to source a titanium replacement bolt for the clamp ring? After taking about five attempts to get the bearing pre-load adjustment right, swapping the wheel in and out of the frame, I think I've finally nailed it. It's running smoothly, with no play or binding.
The Chris King front wheel doesn't seem to have any bearing adjustment - is this correct? The play is barely noticeable at all, but I do think there's a bit of side to side movement. Within normal tolerances, perhaps?
This is my first set of disc brakes on a bike, and I'm not entirely sure how frequently the pads need to be replaced. I've been covering some serious mileage in typically British conditions over the past two months, and I think I may have chewed through the first set of pads already. I remember cooking them in Wales at one point, as there was quite a burning smell noticeable on a couple of occasions. The brakes are Avid Juicy Ultimates. Since the last ride, the bite point seems to be too close to the lever. The contact adjustment (at the lever) seems to make absolutely no difference to this. The initial lever movement also seems a bit sticky. Looking at the callipers, I'm pretty sure I've not got much pad material left. Does this sound like replacement time? How frequently do other users with these brakes find themselves replacing pads? Could anybody give me any pointers to the best replacement pads for UK conditions?
Also, I've got a Hope ceramic bottom bracket with XTR cranks. I frequently take the chain off to give it a clean and oil bath. With the chain removed, I notice that the cranks make a "papery" scraping noise when rotated. They've done this since I got the bike. Is this noise coming from the seals, the bearings, or have I got grit trapped between the components down there that needs to be removed?
I may have a few more questions to add to this thread later in the week, but that's it for now. All advice gratefully received!
- Matt
- Matt
