1 - 2 of 2 Posts
I have had this fork for a while, and it works perfectly. Also, i have checked for wear per the user manual by trying to wiggle the stanchions from the lowers (to check seals)... However, I need to know what kind of maintenance I need to do on this fork, in terms of changing oil, seals, etc....
Thanks for any answers
carpe mañana
Have you ever had oil changed? It is mandatory you do it after ~20 hours because there is a lot of metal debree that comes off all those machined parts as well as due to friction. It is also good to change it once or twice a season, depending on how much you ride. As of the seals, it isn't necessary to do anything about them until your stanchions will start looking moist. check out enduroforkseals.com for info on how to do the oil change.
_MK
1 - 2 of 2 Posts
