uktrailmonster said:Just torque it back up to 100 in.lb and away you go. No need to Loctite it. Check it every few rides, it takes like 10 seconds. Mine has never come loose, but I've heard of others that have. I would only start worrying about it if you find it loosens up again after a few rides.
yep...you do, at least i did. happened to me as well. I simply threw out the darn alloy pivot stuff and bought the stainless steel version used for their tandems, blue loctite, and no more problems.pkyam said:Yeah it looks like I need to hold it from both sides to torque it, and that may require me to remove the right side crank and chainrings... phooey!
