I wonder if the lever body is defective. Doesn't look there is damage any where else in that area.
88 rex said:I always keep my levers a tad on the loose side just in case I have an accident. Today while riding, I went OTB, and when I picked up bike the brake handle had rotated down quite a bit. A quick wack with the hand and it's back in place and no broken parts. I'm loving my F1 too![/QUOTE
Yeah, I do the same. I'm beginning to wonder if my lever housing was defective or had a void in the material or something because although I keep the clamp bolts relatively loose, it did not move. It must have made just the right contact with a rock in order to break in the manner it did. Good news is that it stil works but I am able to push the lever away from the handlebar quite far an in a way not possible with a properly working lever. There is also a bit of excessive movement about the lever's pivot bolt.
Arby said:That stinks. I would take it back to the shop to see what they can do for you. I wouldn't expect that lever to break that easy.88 rex said:I always keep my levers a tad on the loose side just in case I have an accident. Today while riding, I went OTB, and when I picked up bike the brake handle had rotated down quite a bit. A quick wack with the hand and it's back in place and no broken parts. I'm loving my F1 too![/QUOTE
