1 - 9 of 9 Posts
Just ordered the Magura MT Trail Sport Brake Set. Will I need an adapter for the front when putting on a Manitou Circus Expert fork? Looking at either a 160mm or 180mm rotor. The fork is a "Post Mount 180mm" per their web site.
https://manitoumtb.com/product/circus-pro/?cat_id=23
Also, I have a Octane One Zircus Frame that has a "disk brake mount IS (International Standard), max rotor size: up to 185mm" and I am running a Sram Level T brake with a 160mm rotor. Will I need a new mount for the rear - keeping the 160mm rotor? If so, which one?
https://octane-one.com/zircus/
Discussion Starter · #5 ·
Well, even though the web site and the Magura help email said I wouldn't need an adapter to mount the front, I will need an adapter to mount the front using a 180mm rotor.
Bicycle part Bicycle wheel rim Rim Bicycle accessory Bicycle tire
Any idea how long I should make the front brake line? It is as long as the rear. No plans for bar spins or anything like that.
B A N N E D
If you showed Magura that Manitou page for the current Circus fork which has 180mm post mounts, they gave you the correct info, the fork you have is a old model Circus which has 160mm post mounts.
1 - 9 of 9 Posts
