1 - 3 of 3 Posts
i have these great brakes on my stumpy and the rear is rubbing a bit. is the caliper adjustment done using spacers on the mounting bolts or is there another trick i'm missing? i checked their website and the manual doesn't really say much, which i guess probably means adjusting spacers (what a pain). thanks!!
Commit or eat sh!t
If the rotor is already centered on the caliper, you might need to adjust the pistons. Try pushing them back gently. Maybe one of the is sticky, in which case you need to use Magura blood to lube the pistons.
1 - 3 of 3 Posts
