1 - 10 of 10 Posts
I have a set of Louise FR brakes that I would like to change the rear over to 160 from 180, I don't like the look of the adapter on the rear. Can I just loss the adapter, mount the caliper directly to the frame and slide in a 160 rotor?
Also, this is on a new build.
Discussion Starter · #3 ·
It is an IS mount, but I am not sure if the Louise Free Ride caliper is the same as the standard Louise or if they just through in the adapter. There isn't an adapter for the front.
I also have a call into Magura.
Discussion Starter · #7 ·
Got a reply from Magura. The rear caliper is for a 160 rotor and the adapter is to be used with the 180 rotor. As said by someone earlier I can toss the adapter and use a 160 rotor.
The front does not need an adapter.
Pricing & availability & alternatives: 180 rotor with Marta
I want to put my front Marta (160 IS mount) caliper on a Manitou Postmount fork. Adapter # 3 should take care of that, along with changing to a 180 rotor. However, once I go to the the 180, I bet I won't want to go back, but I might want to go back to my current Fox Talas (IS mount, for 160 rotor). It looks like an adapter # 16 will fix that. (???) If so, I could leave the adapters on and swap the caliper back & forth.
2 questions: these are $25 to $29 each for these at Speedgoat. Anyone know of an alternative online source? There is no local Magura dealer.
I know there are some other brands (A2Z, Gatorback, and others). Would that be asking for trouble? It actually sounds like there is enough trouble without going to a different brand.
Do It Yourself
IS to PM options:
1. Get the #3 adapter and 180mm rotor.
2. Get a new PM caliper and stick with the 160mm.
3. Get a new PM brake set.
The website say the #13 is only for Louise (f or r) and Julie (r) only. You'll have to check with Magura to see why. You can order direct:
https://secure.magurausa.com/store/...ES&cat2=Disc+Brake+Calipers+and+Caliper+Parts
I have an extra Magura #3 adapter for when I initially opted for option 1 before switching to option 3 if you're interested. I came to the conclusion that if I'm using 180mm rotors and adapter with the Martas, I'm losing out on the lightweight benefits and better off with a direct mount Louise FR.
Super Moderator
You could also contact Chad @ Red Barn or Larry @ Mtn high Cyclery and they could order the parts for you at competitive prices...
1 - 10 of 10 Posts
