1 - 2 of 2 Posts
No, that's not phonetic
You cannot switch using Magura parts. The caliper end of the hose is permanently crimped. You would have to cut it off and use a compression olive and so forth to attach a straight fitting, none of which magura makes for the caliper end of the hose. The lever end uses the lever body casting as part of the threaded/compression scheme, and this stuff is lacking on the caliper. You could run aftermarket hoses like Goodridge, or just get a new straight hose from Maggie.
1 - 2 of 2 Posts
