From poster rfxc in this thread: "I tested the amp draw from my battery in each of the various modes ( I have the 3 mode light). High draws roughly 1.5 amps, with a range of approx 1.4-1.6. Low mode draws .5amps +/- .1amps. Flashing mode (highest brightness but flashing) draws about .75-.85 amps. Roughly speaking then, Low mode should last 3 times as long as high, and flash mode should last about twice as long as high. Or to calculate theoretically runtime, take the total amp-hour rating of your battery (I think 4.4ah or 4.400mah for included battery) and divide by the amp draw of a particular mode. IE, 4.4ah divided by 1.5amps drawn in high mode = approx 3 hours of runtime with the stock battery."
Seems like low should last about 9.5 hrs and be around 200 lumens.
Re: waterproofing: I used silicone caulking to seal mine. Then, I got the crazy idea to get some Plastidip. I put 3 or 4 coats of Plastidip on it. I have no doubt my Magicshine battery is waterproof.
