1 - 5 of 5 Posts
I'm 6'2" with a 79cm saddle height, and trying to decide if the XL or the L would fit me better.
In terms of reach, the XL might work better if I wanted to run a 50mm stem. Problem is, the XL has a hella long head tube. King Kong long. When you add the A-C of a 150mm pike + the HT, it seems like I'd maybe only just be able to get the saddle even with the bars. If I wanted to run a 160 pike, I don't think I could.
So I was hoping to see what guys in this range are running--did you go for L or XL? What does your setup look like, and what is your saddle to bar drop?
XL is still too small for someone 6'2". Don't kid yourself, great bike but available sizes do not work for anyone over 6' wanting to run a short stem.
Yeah that's wrong. I'm 6'2.5" and loving the sh!t out of my XL with a 70mm stem. For someone my height, I consider that to be a pretty short stem.
To the OP: I'm just about your size, and running almost dead-on your saddle height. I demo'd a L, and found it definitely too small. Ended up getting an XL, which I freakin' love. The HT is long on paper, but I find it to work just fine. See photo of my setup; that's a 150mm Pike, 70mm zero-rise stem, running a headset upper that adds about 1cm, a 1cm spacer under stem, and Havoc riser bars. My grips are still 1-2" below my saddle. If you're worried, a down-flipped stem, no spacers, and a flat bar (I have an ENVE Sweep on my other ride, which is great) would drop your grips another couple inches.
Re: the "king kong" HT, I actually think it's appropriate for this size. Before the M6, I had a BronsonC. It has a shorter HT in the XL, 4.7" vs. 5.9" for the M6. My girlfriend is 5'3", and her Mojo has a 3.8" HT. Her saddle is a good 6" lower than mine, but on the Bronson her HT was only an inch shorter. I know taller riders fit bikes differently, but I ended up running 1.5" of spacers, plus an up-angled stem on the Bronson. On the M6 I can get the bars just where I want 'em without a ton of spacers.
Bicycle tire Tire Wheel Bicycle frame Bicycle wheel
1 - 5 of 5 Posts
