Has anyone had any issues with the rear brake hose routing running it through the guides between the shock mount on the Mach 5?
My XT rear brake has started rubbing inconsistently and i've traced it back to the hose developing a bit of a kink in it and rubbing against the left plate of the rear shock mount. The movement of the rear suspension seems to try and move the hose more than the guides will allow it to move. It's a small size frame and the hose is routed correctly and the correct length.
I've solved it by attaching it to the side of the left plate with a cable tie. Doing this has helped keep the line straighter and the rubbing seems to have subsided.
So has anyone else had any problems like this?
