Hi guys,
I have just serviced my Lyrik U-Turn SI 2008.
It is plushy...but it uses only 70-80% of the travel.
I finish runs with hands pains...
I am around 88KG with all the gear.
I have blue coil\spring in the lyrik.
I've just put 2.5wt oil in the top leg and 15WT in the bottom, amounts according to the manual.
Should I put less oil? will it change something?
Or should I use the red spring? when I used the red i think the sag started with 35-40%.
The fork is simple, only rebound and compression.
The compression doesn't really work, if you turn it, even few clicks, 2-4 clicks, it locks...or almost locks.
Any ideas?
Thanks.
Any ideas?
Thanks.
