I currently have a 2007 Lyrik coil U-turn on my Intense SS. I've been looking for something a bit stiffer and with more travel, and I found someone that is willing to trade me for a 2007 Marzocchi 66 SL1 ATA (140-180mm).
The guy seems like a straight up guy and we would be meeting to do the trade in person, so I am not worried at all about getting screwed. He says he removed the PAR chamber (the bottom out compression adjuster that had the problem with leaking), and the fork has an updated ATA assembly so there are no wind down issues or anything. He says all adjustments work well. Is there anything else I should worry about with the 66 besides the wind down issues?
I tried searching for some information about the PAR chamber, and all I could find was conflicting information about how some people ran zero PSI while others run 30psi more in the PAR chamber than the main chamber. I was wondering if anyone with the fork has removed the PAR chamber and how this affects the fork?
Travel adjust is pretty important for me, I use it a lot to change the head angle of my bike, but on the SS the Lyrik's 115mm is just too low, I never drop the fork lower than 135mm. The added ability of going up to 180mm is a big plus for me.
Should I do the trade?
