Is there a difference in the chassis between a 2018 Lyrik and a 2021 Lyrik that would affect swapping a avalanche damper cartridge?
The new fork I was told came off a 2021 Specialized Enduro and has a build code of 33T00. My old fork is a 2018 with build code 49T7. The new fork has the C1 air spring and floating piston select damper on it so it seems to be a 2021 despite the 2020 build date?
I was told that a 2021 fork has a different length by 30mm and would need new shaft/tube pieces to make it work.
I have both forks apart and I can not see any meaningful length difference. About the only difference I see is the new fork stanchions are machined maybe 1mm deeper into the crown. The axle bosses are different but the old fork is 27.5 and the new is 29. Bottom out bumpers seem to be in the same position. I have put the cartridge in and everything seems fine.
Did I get bad info and everything is good? Is this not a 2021 fork?
