Can someone help me tuning this fork? I can't seem to get it dialed. 2008/9 model, about a month old. Just did an oil change. Replaced the stock medium with soft spring because I wasn't getting full travel. (My shop says this is common with Lyrik, and most riders go at least 1 weight down). I weigh about 190-95 with gear.
I am currently using default setup:
Sag: ~35mm (22%)
Reb: 12 clicks in from open
LS Compression: 4 in from open
HS Compression: 4 in from open
Floodgate: 1 full turn from open
No matter what I do with the controls, the fork feels about the same. Feels a little mushy with lot of brake dive. Any thoughts? Thanks in advance.
Sag: ~35mm (22%)
