The story of this tuning project is the following: I got a pre-production LX Hollowtech II crankset last September for testing. I was astonished how great value it represented: for 85 euros you get an incredibly stiff crankset with bearings that even 100 kg guys you can use on hard terrain for the same weight as my old Hollowtech II XT!
I rode it all winter in snow and salty conditions and the bearins remained smooth. The chainrings were now worn: 3500 km is enough for the cheap aluminum rings. But despite of all the good properties, there was one I hated - the same reason why I gave back the XT Hollowtech II from the previous year (2003) - it had too wide Q-factor for my liking...
I was continuosly thinking about how to reduce the Q-factor. I could get rid of one of the three 2.5 mm spacers if I didn't use the plastic bolt that you use to mount the left arm. (I had to get rid of the plastic tube as well, but I seal the seattube, so nothing enters the BB shell.) But this is only 2.5 mm and my favourite setup, a RaceFace Turbine with 108 mm ISIS BB has some 14 mm (!) narrower Q-factor, so there was a lot more to do to get the crankset the way I like it.
You have to be aware that wide Q-factor only bothers some cyclist. Some actually like to pedal with their feet spread out... I'm not one of them, though I'm not an extreme case like Thomas Frischneck, who uses road-wide pedal-to-pedal distance (155-160). I'm satisfied with the 160-165 mm widths for MTBs.
It is also important to know that I live in a country, where labour costs are low, and you can get a machinist to work a full day on a part like this for 20 euros. (This is how much the whole tuning project cost me + two beers for the guy who polished the arms...)
So here are the steps:
1. The easiest way to reduce the Q-factor is to move the peadals closer to the crankarms. Since I use Eggbeaters, I can't adjust the cleat position sideways, so material had to be taken out of the pedal thread. In the case of the LX, it's not a problem, since the first 3 mm of the hole has no threads: the reason for this is that it shares the design with the Hone, and the latter will have a steel sleeve from 2006, so they had to make room for it. (Why didn't it figure on the 2005 model? - Go and ask Shimano...)
So I had 2,5 mm taken out of the shoulder that had no thread, so the Eggbeater axle perfectly fits into this and makes the connecting point look real nice.
