[youtube width="610" height="343" align="left"]httpv://www.youtube.com/watch?v=iw64NFraWKA&hd=1
The Lupine Wilma TL is the self-contained version of the trusty, sweet-spot light from Lupine. It's not too small and not too big at the $500-$600 price range. And what an execution of the flashlight it is! It is completely sealed with no external charging ports. It is small and extremely bright.
It's rated at 1100 lumens yet it weighs a scant 215 grams. Actual brightness came out to 1000 lumens in an integrating sphere so this light is conservatively rated compared to most other lights in the market.
The battery is charge by unscrewing the head and revealing the charging port. Charging is performed via one of Lupine's fancy lithium 4 hour chargers. It's achilles heel is run time under full power is only 1.2 hours. But that may be addressed by running this light in a lower power mode that can yield 2-3 hours. This is not a bad option when running a light that is over 1000 lumens as that is usually too much light when doing extended climbs.
Specifications:
  • Price: $549.00
  • Claimed Lumens: 1100 Lumens
  • Light Head Weight: 215 grams
  • Installed Weight: 234 grams
  • Run Time: 1.2 Hours
  • Measured MTBR Lux: 113 Lux
  • Measured Lumens: 1000 Lumens
Mounting:
Handlebar mounting is done with a rubber band that comes in standard and oversized sizes. It can be aimed left to right by loosening the allen screw that holds the mount. Helmet mounting is not advised for this light.
Related Links
Mtbr Lights Shootout Main Page »
2012 Bike Lights Shootout »
Backyard Beam Pattern Comparisons »
Trail Beam Pattern Comparisons »
Light Meter Measurements »
Mtbr Lights Reviews »
Mtbr Lights Forum »
MTBR Light Meter Measurements:
This light measured 113 lux on our ambient Mtbr Lux light measurement facility. This compares well to the 112 Lux of the Light and Motion Seca 1400. The Niterider 1500 lumen light is in range too at 115 lux. So in reality, this Wilma TL light is right on par with 1400-1500 rated lumen lights in the market today.
In a laboratory integrating sphere, this light measured out at 1000 lumens. This again is suprisingly bright as manufacturers are typically 20-30% off their lumen claims.
Light Meter Charts and Comparison Table »
Mtbr Lumen-Hour Graphs with an Integrated Sphere
Below is the actual lumen output of the Lupine Wilma TL over time. After an initial startup, the Lupine Wilma TL settles in at around 900 lumens and stays fairly flat for the duration of its run time. At around 65 minutes, it gives a warning flash and near 80 minutes, it gives another flash. It then shuts off completely before the 80 minute mark. The key thing to note here is the light is very consistent throughout its whole battery cycle. This is a sign of a good quality, regulated electronics. Heat dissipation is good too as the light has not problem with heat given our test bed airflow.
Strengths:
  • Excellent light output and beam pattern
  • Extremely compact for the light output
  • Perhaps the best self-contained bike light today
  • Lupine quality and reliability
Weaknesses:
  • 1.2 hours in high means it shouldn't be run in high all the time.
Bottom Line:
This is the best high end self-contained light available today.
Beam Pattern Photos:
The backyard beam pattern is extemely bright in the center area and it has a pretty wide peripheral throw.
Backyard Beam Pattern Comparison Page »
The trail beam pattern is where this light truly shines. It is wide as it shows the canopy and the nearby trail quite nicely. The orange marker at the 100 feet distance is nice and clear. And the green marker at the 200 feet distance is easily visible too. This showcases the awesome throw of the Lupine Wilma TL.
Trail Beam Pattern Comparison Page »
Value Rating:
4.5 out of 5 Stars
Overall Rating:
5 out of 5 Stars
Related Links
Mtbr Lights Forum »
