1 - 9 of 9 Posts
All protection PCBs require that third wire. It's needed to monitor the voltage of the individual cells. That's doesn't imply the protection PCB balances the pack. Without a much better picture of the parts on the PCB I can't say for sure. But it doesn't look like it provides balancing. I base that on what I can make out from the picture. I can see what I think are the control IC, and the charge and discharge FETs. I don't see the other parts that are typically there for balancing. If you can get a much better picture that has readable part numbers on the components, I can likely say for sure.
Discussion Starter · #3 ·
This is the best I can do....I'm still trying to figure out why they can charge $92 usd for this battery....Is there something super special about the PCB? The batteries are standard Samsung 18650's as far as I can tell.
Is there a part number on that top IC in the picture. I can't tell if it's unmarked or just doesn't show in the picture? With that last picture I'm fairly certain it doesn't balance, but would need to look up specific on that control IC to be positive.
With that being said, I'm not sure there's a compelling reason it needs balancing capability. I'm sure Lupine is using well matched cells.
Lupine's protection PCBs are proprietary and required to work with their chargers. My protection PCB failed so I cut it off, dumped the lupine charger and installed a standard PCB and now balance charge my 2S batteries with my iCharger.
Now all my 2S torches (incl the Lupine) are inter-operable with EC5 connectors.
Discussion Starter · #9 ·
I had read that the pcb's were proprietary so my plan is to put a normal pcb in it's place so i can use one charger for all. Glad to hear that someone has done the same thing with success!!
1 - 9 of 9 Posts
