Does anyone have any experience with the 36v Luna charger used for a Focus Jam2? It uses the xt60 connector and I'm not positive that this will mate up with the Jam2 although they look to be the same pitch. There are also two extra small pins in the wiring going from the charger to the bike. I'm guessing that they might have to be closed to tell the bike the polarity is correct before it will start charging.
I'm interested because it can charge at a slower rate to help extend battery life and it can also charge to 80% which can also greatly extend battery life. I don't always want to charge at 4.5 amps and currently only charge to 100% the day of my ride but it's tough to estimate where 80% is in the charge cycle. I'm probably going to not always charge to 100% either. If I have 60% left, which is often the case after my rides I might not charge at all for a follow up short ride of say 15 miles. It's all about making an inaccessible, expensive battery last a bit longer for me. thanks
