I’m considering a Vorsprung Luftkappe in my 2019 Fox 36 on a Ripmo. Small bump and early stroke compliance is petty harsh on this fork, and beats up the hands as well as hard my arms and head causing blurry vision on chatter bumps.
I’ve already removed the single volume spacer from my fork when I converted from 160 to 170 shaft. Luftkappe suggests removing 2 tokens from your pre Luftkappe setup.
I would definitely benefit from small bump and early stroke compliance, but it sounds like the effect of Luftkappe installation will be like adding two VS. that will be way too fast ramp up mid stroke. At least this is my assumption.
Does anyone have experience with zero volume spacers pre and post Luftkappe install?
I don’t want to spend the money to solve one problem while creating another.
