It would help to know what part you're trying to lube up but I'll try and read between the lines..
If it's the freehub/pawls then you can use Mineral oil as an alternative. Although some prefer to use a slightly thicker oil and I have heard of Finish line Wet lube being used. But a drop or two on each pawl with Mineral oil is a better substitute.
