1 - 9 of 9 Posts
When more LSC is added (on a fork for example), does this therefore make the HSC circuit open earlier?
ie, the LSC restricts initial oil flow, hence building up more oil pressure opening the HSC valve, so the more LSC you add, the quicker the pressure builds and the quicker the HSC opens?
Biking Like Crazy!
Yes , your on the right track.
This was covered in one on the Vorsprung Tuesday tunes videos by Steve.
Elitest thrill junkie
Theoretically, yes, but many OEM shock/fork tunes are so restrictive in their HSC that adding more LSC often just makes it harsher.
Underskilled
HSC is the curve created by your shims/poppets/whatever. LSC is the bypass that controls the transition up to this curve.
LSC cannot create more damping force than HSC will support.
So would I be right in thinking, if the shim stack is set perfect, then you would not need any LSC bleed or HSBC preload?
1 - 9 of 9 Posts
