I am looking to mullet out a trail bike and would like to use the fork that will have the least impact on the bike's geometry. Don't get me wrong, I'm fine with raking out the front end and bumping up the bottom bracket. I simply want to minimize those things to the degree that I can.
The bike is a 150mm front, 140mm rear trail bike designed around 27.5 wheels. The head angle is 67 degrees and the bottom bracket is a 338mm. The frame has a flip-chip that will allow me to steepen the head angle to 67.4 degrees and raise the bottom bracket to 343mm. I would like to keep the front travel at 150mm.
So two questions for the group:
-Which non-boutique 150mm 29er boost fork has the lowest axle to crown distance? You would think that this is easy to determine, but I have seen conflicting data. As in, is it really true that A2C on a Fox 36 is significantly less than the A2C on a Fox 34 of the same travel?
-Are there any 27.5 forks that can accommodate a 29x2.6 DHF? I'm thinking "no," but figured I would throw this out to the group.
For background, my Devinci Marshall is currently mulleted with a 29x2.6 DHF up front and a 27.5x2.8 DHR out back. So no need to try to talk me out going down this route. I'm firmly committed to the mullet lifestyle!
