Lowering a 2010 rs revelation xx
827 Views 1 Reply 2 Participants Last post by  MK_
I know you can lower a 2010 rock shox revelation xx to either 120, 130 or 140 if I remember well. But.
Is there any possibility to lower it more, like 110 or even better, 100.
I'm pretty sure I've seen that somewhere, but there is so many kind of revelation, it's confusion with all those solo air, dual air, u-turn, team, race, xx.
Thanks.
1 - 2 of 2 Posts
Thanks.
You can lower it more, by adding more spacers under the air piston, however, the issue you may arrive at is that the negative chamber will not expand enough on full compression to have a negligible effect on the positive pressure which may result in a fork that is prone to wallowing and diving and easy bottom out.
_MK
1 - 2 of 2 Posts
