1 - 3 of 3 Posts
· Registered
Does anybody have a source for bearings for the lower DW link on a V1 Switchblade? I've got a slight amount of play developing in the OE bearings and Pivot is out of stock.
Thanks !!!
· Paterfamilias
Thanks !!!
We use Enduro bearings. They are stock bearings you can buy from anyone that sells Enduro bearings... https://www.endurobearings.com/
If you look at the tech documents and small parts list, you will see the part number for the bearing you need, it contains the Enduro part number as well.
  • Like
Reactions: LVLBTY
1 - 3 of 3 Posts
