Hey
Sounds like your core muscles aren't strong enough. There are a lot of exercises to work on those.
The fork on my bike has an integrated upper crown and stem, which is Specialized's own, so either a) too expensive from lbs b) hard to get hold of second hand (although I keep looking). I have the 80mm and will get the 60mm version when I see one available,d.n.s said:try to shorten stem
No I can't, I will try some stretches along with core exercises.granpa said:can you touch your toes w/only a little knee bend?
stretch the hamstrings - its all connected
I am very much a sit and spinner, I use the granny ring and lowest gears pretty much any time I'm climbing, so I don't think it's due to mashing, but I think there may be a connection to climbing technique as this is when it hurts the most. I will definitely try the hamstring stretchesboomn said:i've had something like that and for me it was always due to mashing too hard a gear while sitting, especially when trying to accelerate in a high gear. If you need to mash, stand up and straighten out your back Either that or gear down and spin at a higher cadence
Like granpa said, its all connected. If you are straining your hamstring from a seated position it can put a lot of stress on your lower back as well
Assuming you don't have an actual physical problem (disc issues, etc), what woodyak said is what I'd listen to. The vast majority of people have tight hip flexors/quads because we sit a lot. What happens is the tightness of the hip flexors/quads pulls your pelvis forward (anterior tilt). The tilt then causes tight hamstrings because they attach to the back of your pelvis. Stretching the hamstrings will likely exacerbate the problem. The lower back hurts because the tilt causes you to use less of your powerful glutes and more of your lower back muscles. As woodyak said, stretch your hip flexors/quads daily and work on glute and hamstring strength. Also, if you sit for your job, try standing up for it. A few minutes of stretching will be wasted if you spend hours with your hip flexors in a tight position.woodyak said:I have the same problem. I saw a chiropractor (who is also a killer mtb'r) and he found nothing wrong with my spine or muscles. He did tell me that I had incredibly stiff hip flexors. He said that was very common with mtbr's because your quads tend to develop quicker than your hamstrings causing your hip flexors and lower back to overcompensate. He recommended doing something (like running) to develop my hamstrings and to do hip flexor stretches on a daily basis. I haven't been great about doing the stretches but I have noticed that it's not as sore and it takes longer rides to get it there. I also went to a PT who also confirmed my really tight hip flexors as well as finding some weakness in my left hamstring. He recommended the same stretches (only more of them) and some things to get my leg strength more even.
It is like that guy who was complaining that he was sold bad vodka - after five bottles he got a headache.Steve.E said:Please elaborate on the 3 hours comment?
