1 - 20 of 26 Posts
I am in a process of building two 2xCree R2 WG lights with the DX 3256 drivers powered by two 4xAA NiMH battery packs (one for each light). As I am planing on using a high quality eneloop batteries, even with almost completely depleted batteries the LEDs should still be quite bright. If I am not mistaken, the NiMH battery packs don't like being completely depleted as there is a chance of destroying the batteries through the reverse polarity.
Don't know if it will help but I made a tiny low voltage warning 'circuit' that lights the red leds when the voltage drops below 4.25V. The circuit is from https://homepages.paradise.net.nz/bhabbott/lvw.html with R3=6k8.
This is what it looks like:
What do you think, is it necessary?
btw ,to answer the "is it necessary" question, I would say yes.
I don't know about the driver you mention but I ran my 4xAA pack down to about 3.3V before I realised my Q5 wasn't very bright anymore.
if nothing else it can give you some warning your light is about to go.
I like Monkeys
dsvilko said:
Sorry, the driver is http://www.dealextreme.com/details.dx/sku.3256. Does anyone know can this driver completely drain four NiMH batteries before I notice a significant drop in the light intensity?
I use the 3256 with 4 AA's, you'll notice it long before the batteries go dead. I'd think that the circuit would be unneccessary.
Lets RIDE!
That's a clever little circuit. Thanks for posting it. How much current do you suppose it uses? Might think about adding it to my battery packs if it's not a significant drain.
I'm kind of ignorant when it comes to electronics. When you say "R3=6k8", what does that mean? 6800 ohms?
How would one calculate the value of R3 for other battery packs?
Thanks.
JZ
Discussion Starter · #8 ·
@JZ:
It seems I have fried a milliamperemeter part of my multimeter so I can't measure the actual current but it should be in the 1mA range. You correctly guessed that 6k8 is 6800ohm. As explained on the linked page the diode will stop conducting current (the leds will turn on) when the voltage drop across the R3 falls below 2.5V. R3 can be calculated from:
R3/(R2+R3)=2.5/Vmin
where Vmin is the voltage at which you want the warning leds to turn on. I think that in place of two red leds you can put one white or blue led to make the circuit even smaller.
@VaughnA:
I guess that's a good news that I will notice a drop in intensity though I must say that I don't understand why should there be a drop. According to Sanyo Eneloop discharge data the cells should fall below 1V maybe a minute before they are completely drained. At 4V the driver should, according to a forum post on DX, still deliver over 0.8A to the leds. Did you do any current measurements with this driver? Can you confirm that it's really as good as the above forum thread would imply (above 0.85A Iout)? Any other advice on using this driver? I am still waiting for my parts to arrive :(
Did anyone here actually destroy a NiMH battery by over-discharging or do I worry too much?
I have problems with my Nimh batteries sometime when my boy leaves a toy switched on and totally drains it.
When i put them in the charger they come up with an error light (might be my crap charger) so what i do is get a 9v battery and stick it in parallel with the AA Nimh to give it
a jump start (about 10 secs normally) and when i put them back in the charger they all seem to charge ok after that.
I had thrown a couple away before i tried that,glad i tried it now!
Tommo.
I like Monkeys
dsvilko said:
@VaughnA:
Well, I'm not using eneloops, just normal NiMH batteries. But the only time I've ever had a dead cell was from letting the batteries sit over the summer without recharging. I run a dual SSC-P4 for about 1-1.5 hours on 4AA's with the 3256, they noticably dim at around 1 hour or so, I swap packs and keep on going.
If you look at many of the graphs of the Current Vs Voltage of the 3256 you'll see that it isn't real tightly regulated. That's why current still drops as the battery weakens. I'm waiting on a 7.4v battery for my next project and I'm a bit worried that the current may higher than I want with that battery. I may end up tweaking the resistor values to drop the current to around 800mA.
www.hahntronix.com
Take a look at voltage monitor chips, sometimes called supervisor chips. They are used to reset microcontrollers when the input voltage goes too low.
These are typically 3 pin devices. One pin goes to the positive side of your power supply (+ terminal of battery in this case). One pin goes to the negative side. The last pin floats (sinks no current) when the input voltage is high enough. When the voltage gets too low, this pin will sink a few milliamps of current. You could use this to turn on an LED with its cathode connected to this pin and its anode connected thru a 1K resistor to the plus side of the battery. Note: make the resistor larger if using a battery larger than 4.8 volts.
There is one supervisor made by Microchip that should work: TC54VC4202EZB. It will trip about 4.2 volts. You used to be able to get samples for free from them, but they now have a $7.50 handling charge in the US. Still, for that you can order 5 of TC54VC4302EZB (trips at 4.3 volts) and 5 of the TC54VC4202EZB.
Or if you need to order something from digikey, look at: S-80840CNY-B-G. It's a supervisor made by sony.
The above examples use TO92 3 pin packages, look like a small 3 pin transistor and are easy to solder to. If you go looking for surface mount parts you'll find lots more.
The advantages of voltage monitor chips is they draw almost no current (microamps not milliamps), they are usually pretty accurate, and typically easier to build into a circuit (3 parts vs 6).
Mark
Discussion Starter · #16 ·
My circuit is still much cheaper and also does not use any exotic elements so in all probability you can buy the parts locally. There is really no need for the circuit to be constantly powered. I'll connect it so it will be powered only when the light is turned on. Additional drain of 1-2mA makes no difference when the LED needs 0.75-1.5A.
www.hahntronix.com
I'm not so sure about the cost being cheaper once you include the precision resistors, 2 LEDs vs 1, etc. The price is about a wash as far as I see.
And if you live live in the boonies like me there is no local source of parts, except for what I have in my junkbox ;)
The thing I like about your circuit is it is adjustable for different voltages.
Mark
Mark
I was going to say the same thing but you can probably add a potential divider on the front of the voltage monitor chip. Only trouble is the divider would be on the supply to the chip as well so you might have problems. I suspect its active draw isn't much though in open collector mode.
I think at the end of the day either cct would be fine, it probably depends on how easy it is to get the bits locally.
Discussion Starter · #19 ·
I just did a quick calculation and the parts for one circuit have cost me about 50 cent. For that price and if you have enough space (maybe go with the SMD components) you could go nuts and make multiple parallel circuits with different trigger voltages and so provide a more detailed voltage indication (three circuits would be a good compromise between precision and complexity).
But it is true that it all depends on what is available in your shop.
Lets RIDE!
I don't know if I could come close to that price unless I was buying the parts in bulk. But I may be able to scavenge the resistors and leds from some old dead computer power supplies I saved. The TL431 will have to be ordered though....my only local electronics source is Radio Shack and they don't list it on their website.
JZ
1 - 20 of 26 Posts
