Does anyone know of a reliable gauge that will work on presta valves, and has a range of say, 0-60 psi?
UST valves (they are presta) are a tad shorter than most inner tube valves.the_eleven said:Sorry for what is probably a dumb question, but are UST valves somehow different from presta valves?
Have you really had good luck with the Topeak? Last I heard of those was that they were difficult to remove from presta valves.
In your experience, of the two you mentioned, which one is more accurate? Easier to use?
I was hoping to find something similar to the Accu-Gage I have. It has a range of 0-160 psi, but doesn't seem to exist for a presta valve in a 0-60 psi range.
