sir, have you been drinking this evening?
Hammershmidt, but I am not sure you would want to run it in overdrive mode most of the time. There is apparently some drag in the drive.nicolicious said:What about 2 gears???? I have a 20T on the back now and it works but if I only had a 16-18T to switch to for nose realll steep climbs I'd think I'd be in heaven'......
Is the such a thing as a 2 speed shifter and drraileer?
Or better yet, do lose weight the economical way...lose 5-10 lbs. off of your butt and you'll never need that granny gearscyule said:First of all, rethink your MATH.....
Beyond that, the guys here have pretty much covered it,
Riding a ratio you can just barely top the local climbs in will be the beginning of getting stronger, put in the work, commit yourself to see the whole SS thing through and have fun
one more thing to think about..... rather than wishing you had one lower gear to go to on climbs ( in your case , actually a 22T cog) consider smashing your piggy bank and getting the lightest wheels and tires you can afford.
loosing a pound or more of rotating weight will get you to the top of the hill at least as well as two more teeth
I'm now riding a 21ish lb Niner but before that a 31ishlb Monocog.scyule said:First of all, rethink your MATH.....
Or just commit to riding the SS and you will lose weight and not have to diet. :yesnod:latedropbob said:Dieting is way cheaper than carbon fiber...
It took me a little while to fully adjust to SS riding after having gears. Trick is to just accept that you cannot sprint downhill anymore and once ou have reached terminal velocity it is time to coast and rest the legs.nicolicious said:2 things--- before I never could get enough strength to get up the climb--- now I get up everything but don't have enough energy to go down - safely anyway...
I thought a 2nd gear would help. But it is only my second time riding- I'll give it time....
And how does a niner weigh 10 lbs than a monocog? From where? The frame?
Wow! and that came in @ 31lbs?driver bob said:It took me a little while to fully adjust to SS riding after having gears. Trick is to just accept that you cannot sprint downhill anymore and once ou have reached terminal velocity it is time to coast and rest the legs.
The Mono is 4130 steel, with heavier wheels and parts:
Steel frame and fork, WTB laserdisc wheels with Felt Hubs, tubes and Bonti ACX tires, generic post and stem, FSA Pig headset, Mary bars, BB7 brakes, generic seat, Crank Bros Candy SL pedals.
The One 9 is scandium with light wheels and parts.
just buy a bike with gears. obviously single speeding is beyond your ability (as is deciding that you think you need a taller gear for the really steep climbs....FAIL) ..nicolicious said:2 things--- before I never could get enough strength to get up the climb--- now I get up everything but don't have enough energy to go down - safely anyway...
Any fruitard that drinks Baileys and egg nog has no business riding a singlespeed.nicolicious said:Yup- eggnog And baileys.....
And a rack a ribs.... Love the holidays
I should throw it back on the scales next time I swing by the shop...It's very possible I weighed it while the DH19's were on there, it was around 18 months ago when it hit the scales (Memory may have added a few lbs or scales may have been off).hallowedpoint said:Wow! and that came in @ 31lbs?
Yep, that's the truth.As the saying goes: Light, Cheap, Strong, PICK TWO
