1 - 11 of 11 Posts
· Registered
I have a 2021 Trek Slash 7. I have been annoyed with the sometines horrendous chain slap the bike makes. I tried completely covering up the seat and chain stays with foam and velcro to no avail. I then decided to record the chain movement on hard hits and noticed that as the derailleur extends from the impact, a wave travels throughout the lower part of the chain and eventually whips towards the chainring making a loud snapping sound.
The derailleur on the bike is a NX eagle with the type 3 roller bearing clutch, which isn't adjustable and many also report that it's weak. Since I can't increase the derailleur tension, I thought about putting a lower chain pulley close to the chainring to prevent the wave from propagating towards it.
Have any of you experienced a similar issue? Any advice would be greatly appreciated.
Slow-mo video: IMG-0967.mp4
· Registered
Go get a 1996 Giant Iguana. Ride it a while and get back to us.
I'll see your Iguana and raise you a 2002 Intense M1.
Sounded like somebody threw a drum kit off the chairlift. LOL
Looking at the video, 2 things:
The chain looks long
The clutch doesn't seem to be working
· since 4/10/2009
in the smallest cog on the cassette, the derailleur is going to be at its least effective at controlling chain slap. you need a bit of tension on the derailleur spring for it to work its best.
This is a great example of a situation where a lower chain guide can help, as well.
· Registered
Discussion Starter · #8 ·
Yes indeed, the Sram Type 3 clutch has been known for being particularly weak compared to shimano clutches. Since it isn't adjustable I can't do much on that regard.
I'll try shortening the chain before installing any chain guides.
· Registered
Discussion Starter · #9 ·
About the derailleur tension, I could increase it slightly by shortening the chain by a small amount, but I'm not sure if it'll be enough.
If that doesn't work I'll probably consider a full chain guide.
Anyways, thanks for the help!
· Registered
Just make sure you leave enough slack for suspension action when in the biggest cog.
Otherwise your chain might shorten itself on a big hit.
· Registered
I wonder if it might not be better to swap out the derailleur to something with a clutch that works.
1 - 11 of 11 Posts
