The bike has relatively low mileage but there is a very noticable amount of clearance between the bolt that goes through the frame and the holein the fitting in the top of the shock. There doesn't appear to be any wear on the bolt of on the aluminum pieces in the upper shock mount that it goes through. There is just a lot of clearance. If you lift up on the bike you can hear and feel the slack.
Is this normal? Is there any fix? It appears that even if I replaced all the parts with new stuff it wouldn't help because there is no significan wear on any of the parts. When I had a similar problem on my AMP - I ended up going from the original 6MM bolt to a 1/4" bolt but I'd rather not be drilling out my new big $ frame.
Thanks for any ideas.
